Calling another roaming phone while abroad
Hi. If I have roaming and call another ROAMING phone while abroad dose this count as calling an Irish mobile? We're going to spain but I just need to be able to call the other roaming phone, Thanks
Hi,
If you call an Irish number while abroad you will be charged the rate for calling an Irish number whether the person is abroad or not, As far as 48 is concerned it is an Irish number so you will be charged the Irish rate. As you are going to spain I would recommend getting the EU Roaming add on:
Roaming calling add-on (includes):€3.50
Making calls and calling your voicemail15 minutes
Receiving callsFree
Roaming text add-on (includes):€2.00
Sending texts25 texts
Receiving texts
Free
10 REPLIES 10
@AbdulrahmanA2296 wrote:
My sim does not acctive in the uk
See here:
https://community.48.ie/t5/The-Knowledgebase/The-Roaming-Troubleshooting-Guide/ta-p/52179
If that doesn't help then you'll probably need to contact 48 support.
