Reply
Accepted Solution
Calling another roaming phone while abroad
‎21-09-2013 06:13 PM
Hi. If I have roaming and call another ROAMING phone while abroad dose this count as calling an Irish mobile? We're going to spain but I just need to be able to call the other roaming phone, Thanks
Posted from Samsung GT-I9505
Reply
Accepted Solutions
Re: Calling another roaming phone while abroad
‎21-09-2013 11:38 PM
Hi,
If you call an Irish number while abroad you will be charged the rate for calling an Irish number whether the person is abroad or not, As far as 48 is concerned it is an Irish number so you will be charged the Irish rate. As you are going to spain I would recommend getting the EU Roaming add on:
Roaming calling add-on (includes):€3.50
Making calls and calling your voicemail15 minutes
Receiving callsFree
Roaming text add-on (includes):€2.00
Sending texts25 texts
Receiving texts
Free
Reply
All Replies
‎21-09-2013 11:09 PM
That's a good question... I'm not really sure! I'd say the best thing to do is just do a test!
Reply
Hi,
Receiving callsFree
Receiving texts
Free
Reply
‎22-09-2013 06:00 PM
Just to be clear - if you are on 48 and abroad roaming and call another Irish mobile which is also roaming then this will not be covered by your membership mobile calls. If you have an EU roaming calls add-on (and both of you are in the EU!) then your call will be covered by that add-on (up to the limit of the minutes available on the add-on). If not or the roaming add-on gets used up then you will be charged the normal roaming rates for calling an EU number:
http://www.48months.ie/boiler-plate/other-call-charges
Making calls and calling your voicemail*29c
Receiving calls*8c
Sending texts9c
Receiving textsFree
The recipient of the call may also be charged depending on their operator and tariff.
I am not a 48 employee - if you need to contact 48 support then please click here - if the Chat Now option does not appear on that page then keep trying until it does.
Reply
‎19-04-2015 08:23 PM
Posted from Samsung GT-I9100
Reply
‎19-04-2015 08:24 PM
Your post is blank.
Did you mean to post a question?
Reply
‎19-04-2015 08:25 PM
I have purchased roaming text for trip to Spain. Will Irish recipient be charged on receiving texts from me.
Reply
‎19-04-2015 08:30 PM
Not if they are with 48 whether they are also roaming abroad or are at home in Ireland.
Almost certainly not if they are with any other network and are at home in Ireland.
Probably not if they are with another network and are also roaming abroad but they would need to check with their operator to be sure what charges apply when roaming.
Reply
‎19-04-2015 08:34 PM
Thanks.
Reply
‎20-12-2022 06:42 PM
My sim does not acctive in the uk
Posted from Huawei VOG-L29
Reply
Announcements
Welcome to the 48Community!
Order a free SIM
Unlock your phone
Ask the community
