Buying add ons
Hi just wondering do you need to have a membership to buy add ons since mine expired thanks
I don't think you need membership to buy add-ons.
But you definitely need membership for add-ons to work.
How much is the minimum top up on 48?
The minimum cash credit balance topup is €1.
https://www.48months.ie/membershop?cat=topup
Memberships cost €10, €15 or €20 depending on which one you buy.
http://www.48months.ie/membership-plans
Add-ons cost between €2 and €3.50 depending on what you need:
rayh5160
How do I top up every month
See here under "WAYS TO BUY MEMBERSHIP & Additional Credit."
https://community.48.ie/t5/The-Knowledgebase/All-About-Memberships-and-Payments/ta-p/53105
