Anyone know what a network MEP code is or where I can get one??
It's the code needed to unlock a BlackBerry handset for use on any network. You get it from the operator to which the handset is currently locked or you might be able to purchase one unofficially online or maybe even get one for free...
http://www.wikihow.com/Unlock-Your-Blackberry
