Any 90 day limitation on EU roaming services?
DanielL2026
Hi, I'm going to Spain for 6 months and I'm not sure if the "roam like at home" EU policy would still apply, or is it only limited to 90 days? If I don't exceed the monthly allowance of 17gb can I use the phone with no extra charge for the 6 month period away from Ireland?
I don't think that roaming is limited to 90 days.
Why do you think that it might be?
I can't see anything about that in the terms and conditions?
Maybe check with 48 support to be sure?
I think that as long as you have an active membership plan for each month then things should work as expected with regard to roaming services.
