48 sim not working in simfree phone
baebae
I put my sim in the phone even though it said my pin was acceppted it still shows no service..and its asking me to enter a pin..i put in my 4digit pin and its not working
8 REPLIES 8
Are you sure that the office is unlocked for use on any network?
What is the prompt for the pin?
Is it asking for the sim pin or the network unlock pin?
Is the sim activated?
baebae
Its asking for network unlock code..i tried different sims and it works but mine wouldnt
baebae
And yes i am 100% sure the phone is unlocked
Network unlock sim prompt normally means that the phone is NOT unlocked for use on any network.
Any update?
How are you 100% sure that the phone is unlocked for use on any network?
If it's asking for the SIM network PIN then it almost certainly is not.
What phone make and model is it?
Where did you get it?
Did you attempt to unlock it yourself?
If so, how?
baebae
I didnt unlock it myself..i bout it sim free..i hve tried other sim cards on it and it works?
What carriers' SIMs did you try?
Did you try more than one?
If you just tried one then it's still possible that the phone is locked to that particular carrier.
Where did you buy it?
From a shop or a private seller?
The network unlock PIN prompt almost certainly means that it's still locked.
Any update?
