0818 call?
Does anyone know if I'll be able to make a 0818 call on the "landline minutes" if I top up? I need to call Sky, 0818719819. Anyone know?
0818 calls are not covered by membership bundled landline calls or a landline add-on. They are charged at 50c/min from your credit balance.
Yes - 50c per min charged from your credit balance - see under All the other call charges > Directory Enquiries and Others
http://www.48months.ie/pricing
Or it maybe you can use one of the alternative non 0818 numbers if they work and are more economical:
http://www.saynoto1890.com/2013/02/s/
This didn't answer my question.
Can anyone else help?
How does "yes you can call 0818 numbers if you have sufficient credit on your account to pay for a 50c/min call" not answer your question!?!?
Of course I can call IF I have credit. DUH!
My question was, if I top up by 10 to pay for my membership, and have 0 credit but 20 landline minutes, will I be able to make the call using the minutes.
So yeah, not quite as literate as you might think you are.
