Using phone in NI
saoirse_m
I’m going to Belfast tomorrow and just wondered if my phone will work up there, I’m assuming not though, so is there anyway to cancel my current membership so I can use the Guido membership to have mobile use up north?
As explained here EU roaming will only work on a Guido membership:
The Roaming Info and Troubleshooting Guide
Unfortunately you cannot cancel an existing membership to switch to another one prematurely so if you're not already on a Guido or your membership doesn't expire tonight then you're out of luck.
Did that help at all @saoirse_m?
