an hour ago
59m ago
What do you mean by "i put 12.99 on 8th of oct and 12.99 today on my husbands revolute card"?
Is this cash credit or did you buy a monthly membership plan?
You need an active monthly membership in order to be able to use outgoing services and roaming.
What does your My48 account dashboard say about your current membership plan status and cash credit balance?
With regard to roaming...
Incoming/outgoing calls?
Incoming/outgoing texts?
Mobile data?
