25-03-2023 07:07 AM
25-03-2023 11:09 AM
Memberships include a European data roaming allowance.
If you use that up then you should be able to buy a data add-on and use that.
You probably need to describe your circumstances and issue in a bit more detail as it's not very clear from what you posted.
Alternatively you can contact 48 support.
See the link in my signature below or email them at [email protected]
