Problem when entering eircode in 48 address form
AalasaF6173
Trying to buy a plan after being away for 2 months, so turned off auto-renew.
The current Plans webpage says to: "Enter you Eircode and select your address in the drop-down menu to proceed." The dropdown doesn't work. No addresses appear. The form submit button is buggy too.
Is there any other way to buy a plan? Could any 48 staff get in touch, please? Unfortunately I need my phone for work 😞
FYI typo in "Enter you Eircode"!
What if you enter the eircode with a space between the two parts - i.e. "D04 TY52"?
If that doesn't help then you'll need to contact 48 support for further advice.
