05-08-2022 09:56 AM
Basically as above, do you lose the old membership rate if you have an older number that you did not switch prior to a rate change and want to do so now.
Thanks
05-08-2022 12:30 PM
I don't think so.
But maybe check with 48 support to be sure.
See the link in my signature below or email them at support@48months.zendesk.com
05-08-2022 03:32 PM
05-08-2022 04:25 PM
I'm pretty sure that just porting a number in will not bump you off the old €7.99 membership, but you might want to check just to be 100% sure... 🙂
05-08-2022 07:06 PM
Judging by this, the only thing that would bump you off being able to buy the €7.99 membership would seem to be if you bought another membership at some point.
https://48.ie/legal/terms-and-conditions#29
05-08-2022 09:48 PM
