Bought wrong plan
louisejoe
Hi there, I bought the wrong plan. Thought I’d purchased the guido but bought the MITCH instead. Can you help me revert to the Guido please?
If the new plan hasn't already started then contact 48 support and they can probably sort it out.
If it has already started then you are probably stuck with the wrong one for the month.
Did that help at all @louisejoe?
