make and recieve calls while on trial
Judithm1693
i have just recieved my free sim to try out 48. will i be able to make and recieve calls/texts while on trial?
You may be able to receive calls and texts but I don't think that you'll be able to make calls and send texts until you buy a membership.
With the free SIM all you get is a free 1GB of data - no free calls/texts.
https://community.48.ie/t5/The-Knowledgebase/Getting-Started-Try-Before-You-Buy/ta-p/53097
