Very low speed internet
MaryamM5393
Hi foe few days my 48internet is awfully works
When was it working ok last?
Did anything change on the phone in the meantime?
E.g. software update, settings changes, factory reset/restore, new handset, returned from roaming abroad, etc.?
What sort of download/upload speeds are you getting?
Are you on 4G or 5G?
Are you sure that your APN settings are configured correctly?
If you're on Android then see here:
Do you know anybody else locally on 48?
If so what is their experience?
