Running out of data and need more
Any one can share me 3G of data please Running out of data few days before my next one start 😂
You can probably use the Flexi Data "Spot Me" option to borrow 1GB from your next plan:
You could also buy 1GB data add-ons as needed:
If you're regularly using up your membership plan data allowance and aren't already on the €12.99/200GB plan then you should probably consider switching to it.
