Roaming issue
I got the guido membership last week and everything was working perfect in Ireland. I'm in Cyprus now and I don't have roaming because I can't make calls or send texts or use data.
If so then it's probably this issue due to the stupid way that Apple do things:
iPhone abroad issue
You may have to be persistent and try that tip many times before it works.
Switching airplane mode on and then off and then trying the reconfiguration quickly may help by allowing the phone to brielfy "catch" the local network allowing the relevant settings to be changed.
As I say blame Apple for this stupidity.
Did that help at all @cathalodriscoll_98?
