Replacement Sim Problem
legomonster1
I got a replacement sim as I needed a smaller size, but now my data won't work. It is constantly 'H' whereas it used to go to 'H+'.
Are your sure that your internet settings are correct?
http://community.48months.ie/t5/The-Knowledgebase/My-Internet-is-not-working/ta-p/45928
What actual speeds were you getting with the old and new SIMs/phones?
Presumably you're using a different phone so that rather than the SIM could be a factor here?
11 REPLIES 11
Did that help at all @legomonster1?
How long do I have to wait for sim replacement?
When did you order it?
Not really sure why you're replying to an almost 4 year old thread though... 🤷‍♂️
legomonster1
I visited the link, but my phone isn't listed. I have a Google Pixel 3a but the latest they have is the 3. I tried pretending I had a 3 but nothing happens..
You need to read and follow all the instructions in the link that I posted. In some cases you may have to configure the settings manually.
legomonster1
Ah, I'm blind. I clicked on that first link and went through the phone choices thing, but didn't look down further. Seems to be working alright now. 👌
This link that I posted above contains a list of instructions to follow if the tweakker option also mentioned at the top doesn't work.
Sorry - THIS link
