How will roaming in the USA work
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report this post
12-09-2024
12:02 PM
- last edited on
12-09-2024
12:22 PM
by
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
12-09-2024 12:22 PM - edited 12-09-2024 12:23 PM
See here:
Note that you won't be able to make calls and receiving calls, sending texts and using mobile data will need cash credit to pay for these services.
Also be aware of the following...
- https://community.48.ie/t5/The-Knowledge-Base/The-Roaming-Troubleshooting-Guide/ta-p/52179
- https://community.48.ie/t5/Internet/How-to-fix-no-network-service-when-roaming/m-p/56352
If I was you I would have a plan B prepared just in case - e.g. getting a local SIM for the trip or something like that.
