18-01-2024 03:03 PM
18-01-2024 03:35 PM - edited 18-01-2024 03:46 PM
You'll need to explain what you've done to set up the hotspot and what exactly doesn't work.
Does your mobile data work?
If not then you'll need to configure your APN settings first.
Text "APN" to 50048:
If you happen to be using an iPhone and are having problems configuring the hotspot then see here - the section titled "A note about personal hotspot setup on iPhones":
If you need to contact 48 support about this then see the link in my signature below or email them at [email protected]
31-10-2024 11:46 AM
31-10-2024 12:11 PM
Did you read my previous reply?
The same questions/comments apply to your query as to the original one.
