Changed phone and mobile data not working
AnaM8004
Recently I changed my phone and my mobile data is not working how I can fix this?
Thanks
You probably need to configure your APN settings for mobile data to work.
See here:
If you're on Android then you can text "APN" to 50048 and follow the instructions here to do this:
