02-11-2021 11:25 AM
Hi, I have seen the thread by Cormac but this solution is not working for me in Germany (How to fix no network service when roaming)
I have just returned from Germany, and my data roaming yet again has not worked. The data roaming connection was really slow and unusable, I had to find WiFi all the time. I read through the help section already, but the issue is as soon as I arrive in Germany, my APN settings are being deleted or I can only see "tescomobile.liffeytelecom.com" APN (which neither works), and when I try to manually enter the 48-APN settings, it NEVER allows me to save them. As soon as I enter MCC (272), or MNC (11), and then save it, the APN simply disappears! If I try without MCC and MNC, the connection is totally useless. If I try to save MCC and MNC, the APN setting disappears.
This is what I have tried:
- tweakker setting for my Galaxy A51: configuration message never arrives
- Data roaming enabled
- Mobile Data enabled
- 48-SIM menu: "When Abroad": "Automatic network selection" - also alternated with "Manual selection" and synched with network settings, no joy
- NOT on airplane mode!!
- manually setting of APN:
MMS Proxy: 10.1.11.19
MMS Port: 8080
MCC: 272
MNC: 11
APN Type: default,mms,supl
-> simply won't save and disappears!
I can only enter Name: 48 Internet, and APN: 48months.liffeytelecom.com, and this gives a really bad internet connection. Tried select manually selecting network operators, for e.g. if I try to select Telekom.de, it tells me the SIM-card is not able to connect to this network. It automatically selects either O2 or Vodafone.
MCC and MNC are prepopulated with other numbers (I think 202 and 08 respectively), and when I edit it won't save and disappears, as described above.
Somebody please help as I can't have this problem each time I travel abroad! What am I doing wrong, or does 48.ie roaming not work with partners in Germany for some reason, is there no roaming agreement in place with Germany?? It's the exact same for my whole family, we are 5 people on the same plan, same issue with each device, each time. Phone and text messages work no problem! Thank you!!!
