Solved: 48 Android App Issues: redirecting to the 48 Community
Issue: you've opened your 48 App on your android phone so you can check out the features and top up or purchase an add-on. Instead, you've found yourself redirected to the 48 Community. Not cool! We know being able to use the 48 App is important to you and your lifestyle so we've worked hard to exterminate that bug!
The solution: It's quick and easy; all you need to do is update to the newest version of the 48 App.
Important:
What if you don't have auto-update turned on in your settings?
What if your 'update notifications' settings are turned off?
48 Community Team
(Bug Exterminators)
