Who Me Too'd this topic
Can't get online?
dc888
Crew (retired)
Crew (retired)
Try our automated internet settings page.  Why waste time entering all the settings manually when it could just take you a few clicks.
You can get all the settings you need via “My 48”.  Click this link.
You will see our simple instructions page.
Hit the "GO TO TWEAKKER" button and then choose your phone type.
Enter in your mobile number and tick the box to confirm you are not a robot.  Then hit the "CONFIRM" button.
Depending on your phone type you might see the following message.
That means your settings are on the way.  You will also see instructions about how to install the settings.
For certain types of phones though you will not receive the settings by text.  If that’s the case you will see the following screens.
Follow the step by step instructions on the right hand side.
** IMPORTANT **
Ensure both data roaming and mobile data are both switched on.
You should now be able to use 48’s mobile internet.  If not contact a 48 agent.
