Sim unlocked forgot pin
lorcansark
Just wondering how I could retrieve my 4 digit pin back so I can access my network again as I can make any phone calls or text
6 REPLIES 6
See here:
I forgot my PIN or need my PUK
You can also disable SIM PIN locking if you don't need it.
iPhone: https://support.apple.com/en-ie/HT201529
Android: https://www.digitalcitizen.life/how-change-or-remove-sim-pin-android-2-steps
Did that help at all @lorcansark?
pairicmcneill
Hi how can i get my puck code
See here:
Constatinc7945
My sem no worked
@Constatinc7945 wrote:
My sem no worked
Sorry, your post doesn't really make sense @Constatinc7945
You'll need to post more clearly and in more detail about the issue or question that you have.
If you need to contact 48 support then see the link in my signature below or email them at [email protected]
