Searching
rionakilpatrick
My phone is constantly searhing for coverage so my 3G,texts or calls worn work
You seem to be using an iPhone - is that correct?
Did it ever work?
If so then what changed just before it stopped working?
Did you change any settings or update iOS on it?
Perhaps this might help?
iPhone abroad issue
If not then you might need to contact 48 support for more advice:
Any update?
