Roaming not working again in Corfu
almoire
Totally fed up. Everytime I go abroad I have major problems with connecting to roaming. I am in Corfu and I have tried resetting all the suggested options. Looking for customer care and I can't find a messaging button. Think I will change provider when I go home
The chat button hasn't worked for me for a long time either so I usually use email instead.
