Replacement sim card
rachwm1823
Hi there I ordered a replacement sim card as I got a new phone which needs a nano sim. The new sim arrived but it won't activate - any advice?
Thank you
What happens when you try?
Are you absolutely sure that you're doing things correctly?
You may need to contact 48 support to get this sorted out:
