Problems registering on UK network
aj159
While in the UK last month I had difficulty registering with any network. Eventually I managed to register with Vodafone UK after 4 hours searching all available networks. Is there an issue ?
Many thanks for the response Van Wider. It's a Samsung galaxy mini. I did manage to register on Vodafone UK but it was about 4 hours after I landed. I managed to get a WiFi spot last time but am anxious I won't be easily able to locate one again. I guess it's fingers crossed for next week
What sort of phone?
Not an iPhone by any chance?
If it was then this might be relevant:
iPhone abroad issue
If not then I'm not sure why you had problems.
I had no problems recently with an Android phone in France.
I think I've seen somebody mention the same problem with a Samsung Galaxy phone recently.
I have no idea why this would be since it should work straight off - unlike how it sometimes (often?) doesn't work straight off with iPhones.
Maybe contact 48 support and see if they can help?
I will do. Thanks again for your help
