2 hours ago
2 hours ago
30m ago
If you want to port your number from your old provider to 48 then you just follow the instructions here:
If you have a problem then post back with details and the Community Forum may be able to help you.
48 support don't generally monitor or respond to posts here on the Community Forum so if you need to contact them then you need to initiate contact with them.
