Phone calls
otna286
I cant make calls it wont connect to ring keeps hanging up, I am paid up and have lots of credit remaining, does anyone know how to fix this , thanks
Could be due to the outages affecting three and other networks today.
See here
https://community.48months.ie/t5/Phones/Is-the-network-down-I-can-t-make-calls/m-p/52993#M3196
karenlarkin
Can't receive calls
You'll need to post a bit more detail.
Can you make calls ok?
When did the problem start?
Does it make any difference if you switch off, take the SIM out, gently clean it reinsert it, switch on and try again?
If not then you may need to contact 48 support.
Did that help at all @karenlarkin?
