05-05-2024 09:46 AM - last edited on 05-05-2024 10:19 AM by dalyer
Hiya. My old phone number changed over to a new one. I wanted to keep my old number. How can I change it back to my old number. Thanks
05-05-2024 10:18 AM - edited 05-05-2024 10:19 AM
By default a new 48 SIM comes with a new 089 number.
If you want to retain your existing number then you need to port it over to 48 from your old carrier:
If you need to contact 48 support about this then see the link in my signature below.
Monday
Monday - last edited Monday
Duplicate posts/threads merged.
No need to create multiple threads for the same issue.
Particularly when you already received advice on what to do:
If you can't receive the porting security text because you have no service on your old network then you need to follow the instructions here:
If your old network SIM has no service or you can't receive the security code SMS, then you will need to make contact with your old provider as they will have visibility of your old account.
Monday
Monday
Monday
You'll have to contact 48 support for assistance with this.
