Notification badge
JoeM5493
A notification badge (a little red circle with a number one in it) has appeared on my 48 app. It's there anyway to remove this. There is no message or other information in the app that I can access to remove it.
Thanks
Joe
Is there a notification in the phone's system tray when you drag from the top of the screen that you can dismiss to get rid of this?
I don't see any red dot myself but maybe that's because I dismissed the recent notification about some new recruitment bonus scheme?
I also dismissed recent notifications from 48 in the system tray but the notification badge still remains. The only way I can find to remove it is to go into settings and turn badges off completely but that's not really a solution.
Thank you dalyer for your help.
Joe
Might be overkill, but I wonder what might happen if you uninstalled the app and then reinstalled it?
JoeM5493
I deleted the app, restarted my phone and installed the app again but the notification badge it’s still there. 😞
