30-09-2026 07:40 PM
30-09-2026 07:59 PM - edited 30-09-2026 08:06 PM
If you want assistance from the Community Forum then you'll need to provide a bit more information than that.
When was it working ok last?
What happened/changed in the meantime?
Incoming/outgoing calls?
Incoming/outgoing texts?
Mobile data?
Are there any error messages displayed on the phone?
What happens when you try to use outgoing services?
Any error messages?
Do you have an active membership plan in order to be able to use outgoing services?
