Lost my phone want to keep no
begzter10
Lost my fone ordered new sim got it registered it and want to use number o sim that was in fone but dont know how
6 REPLIES 6
See here:
Change my SIM
Choose the "block" option.
When you get your SIM and new phone you can activate the replacement SIM and continue where you left off with the same account, phone number, membership etc.
You don't want to order a new SIM and activate it as a new rather than replacement SIM which sounds like what you have done?
begzter10
Ya i got a rwplacement sim and put it in new fone i can get into my 48 no bother its just i cant receive calls
Can you make calls?
Can you send/receive texts?
If you scan for networks can you see and connect to 48?
begzter10
Must put credit in and check if i can make calls
You didn't answer my questions.
Any update @begzter10?
