3 hours ago
an hour ago - last edited 48m ago
You'll need to post a bit more information and context than that if you want assistance from the Community Forum.
What exactly do you mean by "locked SIM" and "locked out of my phone"?
What are the symptoms of the problem?
When was everything working ok last?
What happened since then?
If the problem is that you need your PUK then see here:
3 hours ago
