15-09-2017 02:56 PM
19-09-2017 11:22 AM
I asked them around the same time I put up my first post on the discussion forum and the replies I got from you were more useful so I didn't ask them again. I'm home now, but I'll follow up with them again another time to find out if I should be able to use data abroad on Guido and if so, why I wasn't able to, because it would have been really handy to be able to do it.
Thanks again for all your help.
19-09-2017 11:51 AM
OK - that's a shame.
As I said many people seem to have had problems with data not working while roaming in the EU on a Guido membership even though this should work.
In at least some cases changing the APN field setting back to 48months.liffeytelecom.com from whatever it had changed to abroad and then switching the phone or airplane mode off/on rectified the problem and got data working while roaming.
In some cases this did not solve the problem and I'm not really sure what would fix it.
I can't understand why 48 have not been able to fix this issue - i.e. so that it just works and no manual reconfiguration is needed while roaming - or at least explain it in detail and provide a failsafe way of fixing it manually when it happens.
19-09-2017 12:35 PM
Yeah, you would think that data roaming wouldn't be a problem. I've never had a problem doing it with other mobile providers so I'm not sure why it's a problem with 48. If I hear a reason from them I'll let you know. Thanks again.
