10-02-2024
08:39 AM
- last edited on
10-02-2024
11:29 AM
by
Ok so I've been with 48 from the start, I know exactly how to switch over to roaming when on holiday, I could nearly do it with my eyes closed.
I was using a "oneplus 6" but recently upgraded to the "oneplus 9 pro"
The problem I have is there's no option to select "when abroad" etc..
Please help as I'm in the UK with no connection
10-02-2024 11:28 AM
Try these threads:
If they don't help then you'll have to contact 48 support for further assistance.
See the link in my signature below or email them at [email protected]
If your SIM predates January 2023 then you might want to get a replacement in case that helps:
