I have credit! I need a top up on Data: Please topme up now:
bourne
Your post was blank @bourne and the subject line doesn't really clearly explain that the issue is.
What does your My48 account Dashboard say about your current membership plan status, expiry date, and allowance/cash credit balances?
If you have used up your membership data allowance then you need to use Flexi Data or buy a data add-on to continue using mobile data for the remainder of the current membership plan month:
You buy add-ons yourself, you don't need anybody else to do it for you.
If that doesn't help then you'll need to explain more clearly what your problem is.
bourne
Duplicate threads/posts merged.
There's no need to post multiple times about the same issue.
