How to recharge by using credit?
ShivangiS3072
Your post was blank @ShivangiS3072 and the subject line isn't exactly clear.
Are you asking how can you buy a membership plan and pay for it using cash credit on your account?
If so then you simply select the plan as normal and if you have enough cash credit on your account to pay for the contents of your shopping basket then you'll see the options to pay using cash credit or payment card.
If the checkout total is more than the amount of cash credit on your account then you won't get the option to part pay using the cash credit on your account.
If your query is about something else then please clarify what it is.
