How can I keep my current number
RobertoC2935
I already ordered a new sim but I do not want to change my mobile phone. I need to keep my current number.
What do you mean?
You already have a 48 SIM and number?
In that case you should have ordered a replacement not a new SIM.
However if you ordered a new SIM:
then, when you receive it, contact 48 support and ask them to help you activate it as a replacement rather than a new SIM.
A replacement SIM activation will leave everything intact - your accoun, phone number, membership etc.
If you are not already with 48 and are just getting started then, when you receive the new SIM and activate it it will have a new number but you can then port your existing number over from your previous carrier here:
