Can't get 5G on iPhone 13 Pro
YuanchengZ9946
My mobile phone is 13pro. Why can’t I use 5g data? My mobile phone is a 5g mobile phone.
Is 4G working?
If not then you need to configure your APN settings first.
Text "APN" to 50048 and follow the instructions:
For 5G maybe try this tip:
If that doesn't help then you may have to contact 48 support for further assistance.
WilliamK7057
Same for me. I’m on an SE. Changed my data settings to 5G auto but can only get LTE
Several people are reporting problems with getting 5G.
You'll probably need to contact 48 support for advice.
