08-06-2026 07:46 AM
08-06-2026 11:08 AM
What exactly do you mean by "I put roaming"?
What country are you in?
It isn't really clear what exactly your issue is or what you have tried to get roaming working.
If you want assistance from the Community Forum then you need to describe/explain your question/issue clearly.
On the general issue of roaming, the usual generic advice applies...
