Call is Unrecognised
TaylorC0494
I am having problems making calls, sometimes i call people and the call goes through however sometimes i call people and the call says the number is unrecognised. Has this happened to others and does anybody know a fix.
You'll probably need to contact 48 support about this.
You could maybe also try a replacement SIM just in case the SIM is faulty?
The issue only started with my phone since I received the replacement SIM card
Maybe the replacement SIM is faulty and you should try another replacement?
Might be worth contacting 48 support either way though.
WalterL5096
I am having the same issue. Calls I make regularly, daily I’m been told the number is unrecognisable.
Does 48 check these queries ?
