Answering message not activating when number is called
PatrickD2163
Do you mean voicemail?
Did you follow the instructions for enabling/configuring it?
You need to read and follow these instructions very carefully because it's very easy to make mistakes with the required codes/number formats.
If you still have problems then post back with more details.
