Abroad phone not working even though I am guide plan
annieneylon
In Malta on the guide plan and still my phone not working 😢
If nothing at all is working then it's most likely this issue due to the stupid way that Apple do things with iPhones...
https://community.48months.ie/t5/Most-Popular-Questions/iPhone-abroad-issue/td-p/36862
You may need to try that tip many times before it works.
Switching airplane mode on and then off and trying the roaming profile reconfiguration may help to catch it just as it gets a brief connection to a local network allowing the reconfiguration to be effected.
If that's not the problem then post back with more info about what is wrong.
Did that help at all @annieneylon?
