48 says I can't make calls because I'm not registered.
LiamD1895
I've been with 48 for 2 years. Tried to make a call and it's telling me I'm not registered. What's going on?
When was it working ok last?
Can you send a text, use mobile data, receive calls and texts?
Did anything change on the phone recently?
E.g. software update, settings changes, factory reset/restore, new phone handset, returned from roaming abroad, etc.?
Maybe try reseating the SIM just in case it became dislodged?
Maybe the SIM has developed a fault and you'll need to try a replacement?
Can you try it in another unlocked phone first just to see what happens?
