why sim wont work
I bought a new phone and my sim card wont work in it  how do i fix
Was the SIM working for you before in another phone?
What exactly happens when you try the SIM in your phone?
Any error messages?
Is the new phone unlocked for use on any network?
If not then you'll need to get it unlocked first.
Where did you buy the phone?
Any update?
rayogorman
How do I unlock my sim
You mean you entered the wrong PIN too many times and need your PUK to unlock it?
If so see here
https://community.48months.ie/t5/Most-Popular-Questions/I-forgot-my-PIN-or-need-my-PUK/td-p/35067
You can also switch off SIM PIN locking if you don't want it.
Did that help at all @rayogorman ?
