what network covers 48 in Spain?
I regularly vist mainland Spain and it's Surrounding Island's.
I've always used the main Spanish mobile network Moviestar, generally after I arrive, and turn my phone on then search for a network, Moviestar is top of the list.
To clarify, the above mentions top of the available networks list, in no case stating/suggesting a network preference...
Never had any issues!
Remember to have an active 48 membership, and EU Roaming add on, and a little cash credit, just for extra reassurance!
9 REPLIES 9
Great thanks for your help. Will I be able to use my data while roaming in Spain? I have the roaming add ons sorted already but I think ill only be able to use wifi there and not my own data ???
Thanks Olan
Thats correct, 48 do not supply EU Travel Data add on's, which is a real pity, I have always just relied on WIFI locally while travelling.
There are no preferred networks when roaming on 48.
Any of them should work as well as the others.
mirsaab
Such a **bleep** network 😡
Why?
What's your problem?
And why post six times without actually explaining what the issue is?!?
http://community.48months.ie/t5/Memberships/Customer-service/m-p/40739#M446
Do you have to have a current membership for your roaming add ons to work? I am in Spain and my add ons aren't working is this because my membership has expired?
Yes you need an active membership for add-ons and any other services (other than receiving texts/calls) to work.
