top up
bought my top up today. have been wit 48 for awhile. but my credit wont work eventhough its saying i hav 20 credit. anyone help me please. lost without my phone
Topping up your credit balance is not sufficient - you need to buy membership:
http://community.48months.ie/t5/Most-Popular-Questions/What-is-the-difference-between-membership-and...
I but credit to top up my membership but it would't accept my pin, What happen
You mean a voucher PIN? Are you sure that you entered it correctly?
http://community.48months.ie/t5/Most-Popular-Questions-Knowledge/How-do-I-top-up-Overview-of-the-top...
You might need to log a support query to get 48 to help:
simonk9912
Do I have to buy credit and membership
You need membership to be able to use services - calls, texts, data etc. Membership comes with certain allowances for these.
Everything about membership
Where has my credit gone?
You don't need cash on your credit balance unless you will be using services that are not covered by membership allowances and are paid for from your credit balance.
Other call charges
